Discussion topic: Sky glass problem
This message was authored by: Richa4
Sky glass problem
Anyone else having a problem accessing sky glass tonight? It just says there is a technical issue. My internet is working fine on other devices
Re: Sky glass problem
Hi @Richa4 If you haven't already done so try the classic solution of a reboot/restart as this will often resolve such issues.
To do this got to Settings > System Management > Resets & Updates > Restart device.  It takes about 3 minutes to completely reboot. You will have a blank screen for a couple of minutes before the Sky logo appears so don’t be concerned when this happens.
Good luck 🤞
