Discussion topic: Sky glass connection issues
This message was authored by: PG72
Message posted on 18 Dec 2025 07:51 PM
I've just started using Sky glass and the connection keeps bringing up the circle of doom. Is there anyway of having the signal boosted with additional boxes?
Find out more
Message posted on 18 Dec 2025 08:59 PM
Re: Sky glass connection issues
Bi @PG72
You don't say who your ISP is but you can ask them for extenders or you can connect your glass via ethernet/ homeplugs.
Sky say your Glass needs 25Mbps for HD and 30Mbps for UHD. You can check the speed your getting by opening netflix> profile pic > get help? > Connectivity check.
MikeAlanR
