5
This discussion topic has been answered Discussion topic: Sky glass VESA specs
This message was authored by: Jaydon1
Does anyone know what the VESA specs are for a sky glass 65inch
Re: Sky glass VESA specs
@Jaydon1
All three sizes of Glass have a 300x200 VESA spacing.
@Jaydon1
This message was authored by: Debra25
When is says 300x200 for vesa mount do you know which is which 300 acrosss or down I've looked online and it doesn't seem clear which way the measurements are
Thanks Debra
@Debra25
300 width, 200 height.
It's an unusual spacing, but any 400x400 mount should accommodate smaller sizes.
This message was authored by: Laurabensmum
Hello
Does anyone have recommendations for a wall mount for glass gen 1.  43inch tv please. I don't need tilt
Hi @Laurabensmum and welcome to the forum.
The wall mount for the Glass Gen 1 is an integral part of the stand.  See this link Wall Mounting Guide.
Hopefully you still have the large plastic spacers that came with the TV in the original packaging.
