Discussion topic: Sky cinema ?
Message posted on 14 Jan 2026 08:48 PM
Sky cinema ?
Just upgraded to Sky Cinema and that should come with Paramount+ free but I can get Sky Cinema but it will not allow me to access Paramount +.Spent 2 hours in to Sky tec bots but they could not acess it either Paramount+ wanted me to pay £3 a month fpr it but it should be free with Sky Cinema .Had to cancel Sky Cinama..Even Sky could not explain that
Message posted on 14 Jan 2026 09:01 PM
Re: Sky cinema ?
Hi @Rocker12 ALthough Paramount+ is included with Sky Cinema you still have to register which is free.
You can register by doing the following: Use the voice command "My Sky" and then select the following: your products / (enter your PIN) / App Subscriptions / Current / and then Paramount + Monthly. Hopefully it will say £0 per month as you have Sky Cinema. If so select Activate subscription.
Also, see the following link:
https://www.sky.com/help/articles/sky-marketplace-subscribe-to-paramount-plus
Good luck and enjoy Paramount.
