Discussion topic: Sky cinema
Message posted on 16 Oct 2024 07:58 PM
Sky cinema
Hi all, would like some advice on my sky controller. I have sky cinema with my package and while watching I needed to pause but it wouldn't let me. Wouldn't rewind or fast forward either. Not sure if it won't allow it on sky cinema which seems odd... or is it my controller??
Message posted on 16 Oct 2024 08:01 PM
Re: Sky cinema
Try new batteries and then you'll know.
Message posted on 16 Oct 2024 08:36 PM
Re: Sky cinema
If can't be the batteries as it still works on some buttons just not on fast forward or pause etc....
Message posted on 16 Oct 2024 09:15 PM
Re: Sky cinema
@CB99075 wrote:If can't be the batteries as it still works on some buttons just not on fast forward or pause etc....
Try pulling the plug on your unit for a few minutes then plugging back in
if that doesn't work
The remote can be reset and paired again following these steps;
- Press and hold 7 and 9 together on your Sky remote for three seconds.
- Press and hold 4 and 6 together for three seconds.
- Press and hold 1 and 3 together for three seconds and follow the on-screen instructions.
Message posted on 17 Oct 2024 06:18 AM
Re: Sky cinema
Do you pay for the fast forward in your subscription ?
Message posted on 17 Oct 2024 06:22 AM
Re: Sky cinema
I mean ad skipping ? As that might be why you can not rewind, fast forward, or pause, can you do this on any other channels ?
