Discussion topic: Sky Sports UHD, Stutter/Pause/Stops altogether
Message posted on 20 Dec 2023 08:15 PM
I was hoping with the latest QS024 update that the UHD problems would be fixed but sadly no.
Watching the liverpool v west ham game tonight, literally 2 seconds after the game started the picture froze for a few seconds then restarted. Another 10 seconds later, froze again for about 5 seconds then did the "benny hill FFW" to catch up! Then shortly after completely froze (with sound still going). Switched to the HD channel and everything looks fine. The pre-match buildup was absolutely fine. It always seems to be during the actual match that the problems occur.
Every match on UHD channel this happens for me.
My broadband is not the problem. At least 150 mb.
Anyone else had this problem?
Message posted on 20 Dec 2023 08:18 PM
Re: Sky Sports UHD, Stutter/Pause/Stops altogether
Nope, all UHD content is rock solid for me. If you're connecting via WiFi, run a speed test via the Netflix app on the Puck as that will give you an accurate WiFi connection speed at the Puck.
Message posted on 20 Dec 2023 08:21 PM
I regularly check the wifi speed using netflix. Always fine.
Message posted on 20 Dec 2023 08:22 PM
I should mention, this is a sky glass tv not a puck
Message posted on 20 Dec 2023 08:43 PM
Same problem solving applies really, if you're on WiFi run a speed test via the Netflix app as you could be on the limit for connection speed. If you are, this could be due to either WiFi interference or the signal from your router/hub getting blocked by walls etc
Message posted on 20 Dec 2023 08:46 PM
Regularly check using netflix. all ok.
Message posted on 20 Dec 2023 09:00 PM
What speeds are you getting via the Netflix app because for UHD you need a clear 35mbps to the Glass/Puck. If you are close to this limit, you could be hit by stutters etc as the device tries to catch up with the live stream as it doesn't buffer as such in the way other streaming platforms do.
Message posted on 20 Dec 2023 09:05 PM
Varies depending on time of day. The lowest I've experienced is about 90 during peak time.
Message posted on 20 Dec 2023 09:40 PM
You shouldn't be getting any buffering then. Are you running anything that could be interfering or running in the background that could hurt your bandwidth?
We were on 130mbps G-Fast and it was rock solid.. we're now on 500mbps fibre with Sky and it's even better...
You're not on Virgin Media are you as some people have posted that they're having issues
Message posted on 21 Dec 2023 08:52 AM - last edited: 21 Dec 2023 08:53 AM
@Andy-apple Do you run the speed test a few times a few minutes apart?
Message posted on 21 Dec 2023 09:21 AM
Yes. Always do it three times in a row. Always similar speeds. Was about 120mbps during the match.
Message posted on 21 Dec 2023 09:48 AM
I'd suggest switching over to Ethernet rather than WiFi. I've got a Sky stream puck and had the same issue on live sport and only sport when using WiFi. I switched over the Ethernet and disabled WiFi in the settings and I no longer have this issue at all.
the WiFi hardware in the glass and stream pucks is about 3-4 years old and wasn't exactly premium components that were used to begin with.
Message posted on 23 Dec 2023 06:55 PM
Switching to Ethernet seems to have done the trick! Had to run some long ethernet cables into powerlines in awkward places but so far so good! 63 minutes into arsenal liverpool game on uhd channel and no issues!! 🤞
Message posted on 23 Dec 2023 06:57 PM
Just goes to show how bad the WiFi hardware is in these devices.
Message posted on 23 Dec 2023 07:01 PM
I'm using some really old powerline adaptors with the tv end still plugged into a long extension cable. netflix speedtest showing only 60mbps. But it's working fine. I'll call it a win for now!
