Discussion topic: Sky HD controller code for sky glass
Message posted on 06 Jul 2024 02:40 PM
Hello
Have a sky glass TV with a sky HD+ box revision 10 controller.
I checked the site for a controller code but couldn't find one.
Could someone advise on a code for the Sky HD+ controller rev 10 to control the volume on the sky glass please.
Message posted on 06 Jul 2024 02:49 PM
Re: Sky HD controller code for sky glass
Hi @Kosch
I'm not sure you will get one. Sky+ remotes were manufactured long before Glass. Sky glass remotes are designed to use Bluetooth by default to support enhanced features such as voice.
Sky Q remotes are supported as these are also Bluetooth compatible.
MikeAlanR
Message posted on 06 Jul 2024 05:19 PM
@Kosch if there's a suitable code stored in the chip on your remote that will control your Glass tv, this process will find it. It involves searching though every stored code so is likely to be tedious.
If you want to try it:
- Press TV, then press and hold Select and red together. The remote LED will flash twice
- Then press TV and the Standby buttons alternately until the Glass switches off
- When it switches off press Select to store the code.
