Discussion topic: Sky Glass remote won’t slide open
Message posted on 23 Nov 2025 05:00 PM
My Sky Glass remote won't slide open to change the batteries to access my TV.
Any advice?
Message posted on 23 Nov 2025 06:51 PM
Re: Sky Glass remote won’t slide open
Sky literally advises prayer
Message posted on 23 Nov 2025 07:20 PM
Hi @Sims65 I see you have already been provided with a link to the help file so I won't post it again.
Removing the back of the remote can be a problem the first couple of times as it it very stiff.
I find holding the remote at both ends with the buttons down and my thumbs on top and then applying pressure and pushing with one thumb and pulling with the other in the direction of the arrow is sufficient to remove the cover. Note the back only moves a few millimetres and can then be lifted off.
A number of people have found that wearing rubber kitchen gloves helps to give more purchase on the plastic components.
