Discussion topic: Sky Glass remote control voice control not working
This message was authored by: NickRog
When I press the microphone button a talk it then comes up red and says "sorry I didn't quite catch that". Be tried removing the remote batteries, turning off power to the TV and resttting router, but the same thing happens.
Re: Sky Glass remote control voice control not working
Are you keeping the button pressed whilst you are talking?
Avatar for NickRog
Yes I am
This message was authored by: Jporch316
@NickRog
Try the below
Switch tv to standby (either with remote, or with button on side of set)
Switch off at plug
Switch on at plug (no waiting necessary)
When red standby light comes on, press Home button on remote.
Avatar for NickRog
Hi, thanks. Yes I've tried that was well as removing batteries and resetting the router
@NickRog
Have you tried
The remote can be reset and paired again following these steps;
  1.   Press and hold 7 and 9 together on your Sky remote for three seconds.
  2.   Press and hold 4 and 6 together for three seconds.
  3.   Press and hold 1 and 3 together for three seconds and follow the on-screen instructions.
