Discussion topic: Sky Glass not working?
This message was authored by: Linzi+Biddulph
Message posted on 19 Oct 2024 07:59 PM
Everything we are trying to watch nothing is playing just a black screen
Find out more
Message posted on 19 Oct 2024 08:03 PM
Re: Sky Glass not working?
@Linzi+Biddulph 1st thing to try ios unplugging it from the power for around a minute or so, then plug it back in.
Once you've done that and you're still having issues then you need to look at your boadband/wifi speed reaching the tv.
On Glass open netflux, go to Get Help run connection test, this will give the speed reaching the TV.
Anything less than 25mbs for HD & 30mbps for UHD will cause such issues.
