Discussion topic: Sky Glass lip sync issues
This message was authored by: CharlesBish
I have a Sky Glass 43". No aerial and hard wired to a router. Lip sync is so bad it's difficult to watch, different channels are worse than others.
This message was authored by: Jones_The_Cat
Re: Sky Glass lip sync issues
Have you tried rebooting the TV? Turn it off at the wall for a minute then power back on. This usually helps, temporarily at least.
