Discussion topic: Sky Glass issues
This message was authored by: marynolan
Sky Glass issues
My Sky glass keeps freezing but only on sky channels BBC and ITV work perfect
This message was authored by: Jporch316
Re: Sky Glass issues
@marynolan
First thing to to try is either a restart on the settings or pulling the plug completely for a few minutes ....... often clears these type of glitches
This message was authored by: DebsF
I have the same issue on Sky Sports mostly on live sports on HD
That doesn't work for me.
What internet speed are you getting on your glass? You can check this by opening the native Netflix app selecting get help and running the network check
Says 75.1 when I do a check using Sky but when I did the Netflix it showed not connected.
How far away is the tv from the router ? Are you connected via WiFi or ethernet ?
