Discussion topic: Sky Glass - intermittent WiFi issues
Message posted on 01 Nov 2025 07:59 PM
We had had our sky glass for nearly 3 years, and in last 4 months we have seen it intermittently loses WiFi - sometimes this can be reset in the glass menu, sometimes the tv needs to be turned off at the plug. On each occasional all other devices on WiFi are working without issues.
Any ideas how to solve?
Message posted on 02 Nov 2025 09:26 AM
Re: Sky Glass - intermittent WiFi issues
- Sounds to me, more like an issue with your Wi-fi than Sky Glass, make sure your Router is up to date with its software and has been restarted recently
Message posted on 02 Nov 2025 09:35 AM
Thanks Nigel - can you provide more detail as to why it's a router issue - as I said in my original post no other issues with connected devices.
As part of the regular resetting of sky glass connection the router is restarted, it's a sky router that was replaced by sky this year.
Message posted on 02 Nov 2025 10:16 AM
Can you do a network speed test on your Sky Glass TV
Launch Netflix on your pucks (you do not need to be logged into it, if you do not use netflix) and scroll down the left menu to Get help.
Choose Check Network.
Would suggest running the test a few times, say over a half hour period.
What is your speed?
