Discussion topic: Sky Glass automatic default to recording Sky Store.
Message posted on 25 May 2025 03:49 PM
Anyone know how to stop Sky Glass defaulting to Sky Store when wanting to record a film on another channel? It's now doing it when wanting to record a film on BBC 2 gtodasy.
Message posted on 25 May 2025 03:55 PM
Re: Sky Glass automatic default to recording Sky Store.
Glass doesn't record the film. If the film was on BBC2 then you need to try and watch it via the iPlayer app.
Message posted on 25 May 2025 04:05 PM
@Hurc wrote:Anyone know how to stop Sky Glass defaulting to Sky Store when wanting to record a film on another channel? It's now doing it when wanting to record a film on BBC 2 gtodasy.
When you add the film to your playlist is will tend to default to Sky Store or Sky Cinemaz
If you open the film on then playlist and scroll down to the Available Now rail it should then display a "Play on X" button for each app/service that the film is available to watch on.
Its worth nothing that if a film is broadcast on a BBc or ITV channel for instance doesn't mean the film will necessarily be available to watch on their catch-up apps.
Message posted on 26 May 2025 09:20 PM
Thank you although I understand what you are saying, the Sky Glass refuses to play anything other than Sky Store, the latest attempt using Film 4 which previously I never had a problem with.
Thanks for trying though, much obliged.
Message posted on 27 May 2025 06:20 AM
Any examples of current films you are wanting to watch might help explore the issue further.
What were the two on BBC2 and Film4, that might be a good start?
Message posted on 27 May 2025 03:07 PM
Hi Lettice,
Last Sunday the film i wanted to record was Where Eagles Dare on BBC 2. I tried several times in different ways to add to Playlist, but each time it defaulted to Sky Store. So Deleted and asbandoned it. Went bask to the screen a few hours later having switched it off and it had recorded it on BBC 2 as originally intended. Odd!
The previous one was Guns of Navarone which i think was on More 4 and subsequently Film 4. Even setting to record from the actual channel it would only default to Sky Sore although appearing to show it would record on the selected channel, it would not.
Message posted on 27 May 2025 03:22 PM
@Hurc Could it be because BBC and 4 have their own apps for catch up? As @MarkGoldsmith said, there's no guarantee that films or everything they show during a day will appear on it. Because Glass/Stream doesn't offer recording a la Q, you are dependent on the programme/film being offered to watch on the channels catch up service, if that makes sense?
Message posted on 27 May 2025 03:32 PM
Thanks for that and in some cases you are quite correct, howver it wasn't just thse 2 particular films it is an ongoing issue along with certain channels that have a film split into 2 parts and the screen says it will record but in fact on records the first part. Sky say it's a known problem which they said had been fixed but it hasn't changed since 2022 when I got Sky Glass.
Message posted on 27 May 2025 09:06 PM
Just do what i do if the film or program is on bbc, itv, channel 4 or channel 5
Then I go on the iplayer, or itvx, and add to my list on there same with the other channel
Message posted on 27 May 2025 09:20 PM
Thanks for your input. I'll try your suggestion and thanks again everyone else for the advice.
