5
This discussion topic has been answered Discussion topic: Sky Glass Remote Stops Working Overnight
This message was authored by: RLBR
My Sky Glass Remote works fine for as long as you're using it, but as soon as you turn the TV onto standby for a prolonged period, overnight for example, when you go to turn it back on with the remote it doesn't work. The remote lights up as it should but pressing buttons does nothing. The only solution I've found is to remove and re-insert one of the batteries and then it works. Rolling the batteries doesn't work. Does anyone else have this issue or know how it can be resolved?
This message was authored by: MarkGoldsmith Answer
Re: Sky Glass Remote Stops Working Overnight
Try turning overnight power saving mode OFF in the settings and see if that helps
Avatar for RLBR
Done - I'll let you know in the morning!
Avatar for RLBR
It worked! Thank you so much!
This message was authored by: Maadi12
But remote won't work so cannot gey to settings
Hi @Maadi12To help you try to get your remote working the links below are to remote troubleshooting guides:
Troubleshooting guide
Remote help
You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth.  Even though it sounds an unlikely solution it has got many faulty remotes working again (including mine on two occasions).
If none of the above help then I would request a replacement at the following link: Streaming TV replacement remote
If you have one available you can use a Sky Q remote while you wait for a replacement.
