Discussion topic: Sky Glass Power up Issues 19-9-24
Message posted on 19 Sep 2024 11:32 PM
Re: Sky Puck & Sky Glass Power up issues 19-9-24
That seems to be working for me warlord2001d
Message posted on 19 Sep 2024 11:37 PM
What the puck Sky? I recently upgraded my GigaClear Fibre to 900Mbps especially to support my Sky Streaming "service". Still I had increasingly frequent 'blackscreen' cutouts and then tonight it became unbearable glitching every 5 seconds so I reset it (again) - Big Mistake!
Very poor product and service - so much so, I'd switch back to my old Sky HD 2TB Satelite box if I could.
Re: Sky Glass Power up Issues 19-9-24
Just did a hard reboot and it coming back to life
Not happy waiting to hear how much my bill will be reduced
Message posted on 19 Sep 2024 11:43 PM
Just done the sky glass update and 🤞it stays up and running... went a whole day without tv hope sky compensate as not been able to watch all day
Message posted on 19 Sep 2024 11:46 PM
Tv
My sky glass TV has been flashing red light on and off for an hour and will not turn on I have tried unplugging the Leads unplugging the TV from the wall and tried new batteries I'm not sure if the TV is broken but it's been working perfectly fine so I can't imagine there is a fault
Message posted on 19 Sep 2024 11:52 PM - last edited: 20 Sep 2024 12:41 AM
Puck back up and working after performing the recovery process.
Build version now QS033.
Apps did not lose login details.
Edit: I have also discovered that my other pucks which had been working throughout the problem (presumably because they were powered on all day ) also fail when power is removed and then turned back on.
I have had to perform the recovery process on all pucks.
Re: Sky Glass TV won’t turn on after power cut
Hi!
Thankyou so much for your help and support.
It has finally turned on now after I left it unplugged for the last 20 minutes!
I have saved your links in case I ever face this trouble again.
Much respect,
Jane
Message posted on 19 Sep 2024 11:57 PM
Sky glass
Sky glass just has pulsing red light, tried unplugging, pressing buttons on side of tv and on the remote. Looked on my sky and apparently lots of people are having this problem right now. How do I look for updates on the matter/ get answers on how the problem is sorted ?
Message posted on 19 Sep 2024 11:58 PM
I got to a complete set up routine, then kept telling my pin was wrong before I even put it in, reset it and still didn't recognise any attempts, so now doing the switch off on thing waiting 30 mins to see if that works. Would much rather be getting some shut eye, got to be up for work at 6.30, but won't settle until I sort this
Message posted on 20 Sep 2024 12:00 AM
Currently experiencing the same issue with my Sky Glass tv. The standby light continues to flash but the tv will not switch on. Is anyone else having am issue with the sky glass tv or is it just the puck?
Message posted on 20 Sep 2024 12:01 AM
Re: Sky stream won’t turn on - flashing white light then nada.
Same fault hear flashing white light and SKY flash screen then powers off and repeats every ten minutes or so appears it's been down all day and still no resolve unplugged for ten minutes did not resolve the issue hopefully sky will rectify this soon
Message posted on 20 Sep 2024 12:02 AM
Yay, I'm sorted. 10 minutes did it, thanks guys, I owe you one
Message posted on 20 Sep 2024 12:13 AM
Sky puck still won't turn on
Message posted on 20 Sep 2024 12:15 AM
Puck issues....
I have a major problem, like many our puck is refusing to turn on.
A night without TV turned out to be a nice (quiet) change, but there is a problem. My wife decided we should spend some time chatting, after grabbing my lap top , opening " Messenger" and initiating a "chat" , she got up and stomped off ! What did I do wrong?
