Discussion topic: Sky Glass Power up Issues 19-9-24
Message posted on 22 Sep 2024 03:17 PM
Re: Sky Glass Power up Issues 19-9-24
Just tried the reset for the 3rd time but you have to wait for the red light to flash quickly, not just slowly like it does when you first do it! Hold reset button for about 20 seconds..... it worked for us finally!
Message posted on 22 Sep 2024 03:21 PM - last edited: 22 Sep 2024 03:23 PM
Re: sky puck
@billsboro wrote:its not sky glass its a puck and nothing works
@billsboro The same instruction PAGE covers both Glass and Stream pucks. Just select the correct one (just right of the top of the blue line)
Message posted on 22 Sep 2024 03:22 PM
To Docer64
That is the exact problem i have inputting the code does absolutely nothing.,Dave
Re: Sky stream issues
I'm new customer as of Thursday 19th stream went off Thursday night . Tried the re boot thing , didn't recognise pin so changed pin didn't recognise that either . Plus landline does not accept incoming calls waste of £££ I'm leaving sky
Message posted on 22 Sep 2024 03:26 PM
Yep my contract is up in October so time to move on I think.
Message posted on 22 Sep 2024 03:27 PM
So frustrating isn't it! Tv started up, software installed, remote connected - doesn't fancy completing the final stage.
lost count of the amount of hard resets, factory resets, restarts, different browsers, different networks, different devices....
arghhh
Message posted on 22 Sep 2024 03:28 PM
Re: Sky.com/activate not working
I've been trying for the last week, Every night after work on the phone and ends up hanging up when they close, been a sky stream user for 3 days and then last week haven't been able to watch or sign in on the account, Couple more hours on phone right now and if they do not answer I am cancelling my sky tv and broadband and moving to bt , sky.com/activate doesn't work disappointed
Message posted on 22 Sep 2024 03:29 PM
At the puck (red) stage and then software update and then activation code. How do you activate this. I've tried going into my app (and I don't know where to type it in?)
Message posted on 22 Sep 2024 03:30 PM
No nothing works!!! As an elderly disabled person this is bad customer service!!!
Message posted on 22 Sep 2024 03:31 PM
Re: Activate sky stream
Didnt work
Message posted on 22 Sep 2024 03:32 PM
You have to go into internet and type in sky.com/activate and then put your code in there but I've been trying for the last couple days and system is down as says oops there's been a problem pathetic
Re: Compensation from sky?
Hi super
have exhausted every option, with precision and patience but the latter is thining.
Message posted on 22 Sep 2024 03:33 PM
@docer64 yeah im very close to closing my subscription mainly because of the diabolical customer service after 4 days of no service at all they should be announcing progress on email or in newspapers. All I've seen is a small report in the Sun intimating a small problem easily fixed. Disgusting.
Message posted on 22 Sep 2024 03:34 PM
Thanks - tried that yesterday and it didn't work. Will give it another go
Message posted on 22 Sep 2024 03:37 PM
Thank you. Unff seeing the earthnet worked for me! It allows the Sky glass to get the required update. It's now back up and running in the bedroom.
Nice one 👍🏽
