Discussion topic: Sky Glass Power up Issues 19-9-24
Message posted on 19 May 2024 12:07 PM
Re: Sky glass tv won’t turn on just flashing red light
Hello matey, I'm having the same issue. Tried what you reccomend and still nothing
Message posted on 19 May 2024 04:43 PM
@DannyBoy24 wrote:Hello matey, I'm having the same issue. Tried what you reccomend and still nothing
Does it turn on on the button on the side of the tv ?
Message posted on 18 Aug 2024 12:47 PM
Did this issue get solved? Ive followed the thread but mine just goes back to flashing after trying all of the above.
Message posted on 19 Aug 2024 10:40 AM
@Bexster77 wrote:Did this issue get solved? Ive followed the thread but mine just goes back to flashing after trying all of the above.
If you've tried the troubleshooting then you'll need to ring Sky. If your Glass TV is still under warranty and has developed a fault then they will replace it. If it is not under warranty then you'll either need to pay for a repair or buy a new TV.
Message posted on 19 Aug 2024 10:52 AM
Thank you @Mister_Dalek
Message posted on 19 Sep 2024 03:44 PM
Sky glass tv won’t turn on red light just keeps flashing
Sky glass tv won't turn on red light just keeps flashing
Message posted on 19 Sep 2024 04:15 PM
Stream puck won't turn on
Message posted on 19 Sep 2024 04:19 PM
Re: Sky glass tv won’t turn on red light just keeps flashing
I've got the same problem but it worked this morning
Message posted on 19 Sep 2024 04:35 PM
Mee too
Message posted on 19 Sep 2024 04:36 PM
Sky glass to not powering on. Tried reset not working. Sky on phone 50min hold time. Anyone know e
Sky glass not powering up
remote appears ok
sky puck box not getting a signal
ttoed resetting get Sky logo then nothing
Message posted on 19 Sep 2024 04:38 PM
Hello I've tried this. My tv doesn't turn on from the button on the side of the tv and the tvs red light at the bottom is still flashing. The issue is my dad gave me the tv as a gift and I don't talk to him anymore and I don't have contact with him. I need some advice as I can't really do much about it.
Message posted on 19 Sep 2024 04:39 PM
Re: Stream puck won't turn on
I'm having the same problem it's really annoying it just flashes won't even let me hold down the 4&6 does nothing I've tried hard resetting it the logo appears on the screen then goes off again it's so annoying
Message posted on 19 Sep 2024 04:40 PM
Re: Sky glass to not powering on. Tried reset not working. Sky on phone 50min hold time. Anyone kn
Having the same issues ourselves.
Message posted on 19 Sep 2024 04:41 PM
Sky glass won’t turn on
My sky glass tv is 3 years old, today it won't turn on and the red light won't even appear, I know the plug is fine as the sky camera right light is coming on just nothing for the tv any one any tips, when I turn off and on while holding the power button the screen comes on, resets then all goes off again
Message posted on 19 Sep 2024 04:42 PM
same her, followed all the diagnostics on the website, still not working
