4306
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
This message was authored by: thomasdinu21
My sky glass is not working. Its not getting switch on
19/09/24 After watching l switched of the tv by remote.. After that my son disconected. Ather that today 20/09/24 i try to switch on. I pluged in and switch on the electricity its not geting on.
This message was authored by: terrywatts8
my stream puck has stopped working on 19 august 24
My steaming puck stopped working on 19th August. I have tried rebooting without success.
The problem is not with my wifi as sky go on my Ipad is working ok.
Is there a ploblem in my area
This message was authored by: LiamFletcher
Re: Sky Glass Power up Issues 19-9-24
I have tried this multiple times and getting nowhere, when are Sky going to resolve?
This message was authored by: PaulRC1963
Workaround not worked
So much for the "fix" that Sky has told people to do. I've reset one of my Sky pucks 3 times and can't get past pin and reset pin multiple times and still says it's incorrect.
currently on phone to them now. This is just ridiculous. So for all the people saying it's a fix, it clearly isn't.
This message was authored by: Symonsmark
Re: Changed PIN but keeps saying Incorrect PIN- ATTEMPT 0 OF 3
Brilliant Mark. Thank you. 2 hours telephone and chat but no reply from Sky. Your solution worked first time. Thank you.
This message was authored by: Hoppy+55
Stream tv
Why are admin locking posts, when we all want to know what's going on !
Dh
Re: Workaround not worked
And the multiple posts in this thread where it has worked?
This message was authored by: larky+marky
Tried it at least 20 times on stream.
I get a code to link my account but the Sky page says 'Oops, there's a problem'
Everything you do just goes around in circles, it's rediculous.
Sky seem to have two people in their so called 'call centre' and one is always on a break.
Sky customer service is disgusting.
FORTUNATELY, I can watch TV on my laptop (F1) but it really is not good enough for 2024!!!!!!
This message was authored by: Lauren222
@TimmyBGood  I was on the phone with sky when mine didn't work, I have to wait for a phone call back to order a new glass tv as mine is not responding to this so called fix?
This message was authored by: Joe090
Waaaaaaaay too many people here clearly NOT following the correct(!!!) reset instructions for the puck...
For the puck :-
1) Turn it's wall socket power OFF (or unplug the power cable from the puck)
2) Press - and KEEP HOLDING - the small 'power' button you will see underneath the puck (circle with line) - as you turn on the mains power (or plug the cable back in). Keep holding in that button!
3) Keep holding in that button till the led changes from flashing white - this WILL take around 10 seconds
4) Once the led changes colour let go of the reset button and follow the on screen instructions.
The units are NOT bricked by the recent update, but they WILL need reset. If you follow the above instructions and are NOT seeing the puck initialising (with on screen instructions) then you are doing something wrong!
It's not working for me. 🙄
Avatar for GD1
Level 16 icon
Re: Stream tv
No posts have been locked, if you look at the ones showing as locked it's because they are being merged into the existing thread regarding the Powering on problem.
This message was authored by: Kirsten741
@Lauren222 Are they asking people to order a new one?
I've done all this, it's rebooted but now stuck on the incorrect pin garbage. Reset pin 5 times and it's still saying incorrect.
This message was authored by: Randip
Link Sky Strean puck to my account via app
I have reset my sky stream due to outage in area. I'm.on the final step requesting to enter code to link my account which enable me to watch channels. Where on the app do I go to link my account? Thanks
Locked
Answered - Go to Answer
