Discussion topic: Sky Glass Power up Issues 19-9-24
Message posted on 20 Sep 2024 01:29 PM
sky stream now working
Try the recovery process
- Switch off your TV at the mains. There's no need to unplug it.
- Press and hold the Standby button on the right-hand side of the TV.
3. Keeping your finger on the button, switch the power back on at the mains and wait until you see the LED lights flash (this could take 20 seconds before the LED starts flashing), then remove your finger.
4. Let the Sky Glass TV complete the recovery process. This can take up to 15 minutes, depending on your broadband speed.
Re: Sky Glass Power up Issues 19-9-24
Red led is still flashing after trying the hard restart. Is this supposed to work for everyone?
Message posted on 20 Sep 2024 01:30 PM
Still not working, runs through some kind of update shows Sky logo a couple of times then red light flashes. I press 7&9 together then continue but it won't connect to router.
I've tried this multiple times and still getting the same error message
My Ky
When will my Sky Glass be up and running??
And why wasn't I notified (had to get info from X)
If been spending most of the morning trying to fix it! 🙄
Message posted on 20 Sep 2024 01:31 PM
MY RED LIGHT ISNT EVEN COMING ON , just the microphone sign lighting up , tried the answer in the post
A reboot won't work you have to follow the recovery procedure as outlined by Sky on their service checker.
https://www.sky.com/help/articles/sky-glass-stream-wont-turn-on
MikeAlanR
Re: My sky glass tv isn’t working properly
@Alan155 I have merged your post to this existing thread that is discussing the current issue, the thread you tagged on the end of is unrelated to this issue. There is no 2nd line support number.
Please try the steps in the post marked as answer
Message posted on 20 Sep 2024 01:32 PM
- @Kirsten741 same here, no red light since this morning when I first tried to turn the TV on. Only the mic light is on, tried resetting via the "given answer" on here but no luck. I guess it's just a waiting game at this point.
Message posted on 20 Sep 2024 01:33 PM
@Mel112 wrote:
Is everyone still having problems with their stream pucks. I've followed the steps to reset it which worked. Linked sky account worked but then tried to pop pin in and now blocked me from signing due to wrong pin (which it wasnt). I've been off since early last afternoon and still no luck
As mentioned in post 2 answer.
If you have a problem with entering pin.
Power off the puck or Sky Glass TV and power back on again and it should work.
My little girls sending me nuts honest to god so stupid what other telly does this🙄🙄
I cannot even get my tv to turn on after trying everything suggested even reset router We have glass tv but watch through sky q which is working in the bedroom on a normal tv so not sure what is going on
Sky glass not coming on
Is anyone struggling to get sky glass on? Just red light on the front
Message posted on 20 Sep 2024 01:36 PM
Re: Sky glass not coming on
I've moved your post into a large thread discussing this issue. See post 2, currently showing as the answer.
