This discussion topic has been answered Discussion topic: Sky Glass Next Episode
Message posted on 28 Jan 2026 02:32 PM
I had a Sky Glass Air delivered yesterday. All good except for an anomaly with the playlist.
As I understand it, when you add a tv show to your playlist and you subsequently play an episode, the next time you go to that show, it should bring up the next episode. Trouble is, it doesn't.
For example, I was watching Stargate SG-1 on the Sky Q box before the Sky Glass Air was delivered. I then added it to the playlist on the new tv, but despite being half way through season 8, every time I go back to it, it wants to play season 1 episode 1 and i have to remember which episode I'm up to.
Any ideas why this is?
Message posted on 29 Jan 2026 02:36 PM
All sorted. The engineer who fixed our broadband had to unplug the tv and plug it back in for it to connect to the internet. Next episodes are now showing.
Thanks for the help
Message posted on 28 Jan 2026 04:24 PM
Re: Sky Glass Next Episode
@falbs wrote:I had a Sky Glass Air delivered yesterday. All good except for an anomaly with the playlist.
Hi @falbs welcome to the glass forum !
does it do it on all shows or just stargate?
If just stargate you could try removing the show from your playlist then restarting the tv from the settings menu. Then add it back in again
failing that and it's just stargate you could try emailing [email protected] who can deal with metadata issues for programming
Message posted on 28 Jan 2026 04:27 PM
Thanks for you reply. Unfortunately, it appears to be for all shows. Stargate was just an example
Message posted on 28 Jan 2026 04:28 PM
try pulling the plug out for a few minutes
if that fails report back here an I will escalate your post to the online community team
Message posted on 28 Jan 2026 08:23 PM
Will do, but will have to wait as our broadband has gone down!
Thanks for the help
