Discussion topic: Sky Glass Dropping Wifi even when using ethernet
Message posted on 17 Jun 2026 04:17 PM
Message posted on 17 Jun 2026 04:24 PM - last edited: 17 Jun 2026 04:31 PM
Re: Sky Glass Dropping Wifi even when using ethernet
This is a problem that does seem to pop up now again and I'm not sure its been resolved for some customers
As you are using etherent, have you in the Sky Glass network settings turned off wifi?
It will at times move over to a wifi connection, rather than the ethernet connection, if that is not set.
I think from your post yiu may have already done so.
Even, if you have, try toggling off and on and then do a settings restart of the Sky Glass TV straight away to see if that helps set the option.
One thing you could try, as using ethernet is to assign a fixed local ip on your BT router, that may help keep the connection more active.
Message posted on 17 Jun 2026 07:26 PM
Configure your Glass to use a static IP address. This requires router configuration, not the TV as it has limited options.
Router? Two TP-Link Deco BE65’s (v2 / Firmware Version: 1.3.5)
Message posted on 17 Jun 2026 09:52 PM
Thank you. I've got wifi switched off but have toggled it on and off and reset the TV so will see what happens. I'll look into the fixed IP address idea too. I've heard it suggested that we should try to wake the TV up using the Home rather than power button so will try that too. Cheers
