Discussion topic: Sky Air WiFi
This message was authored by: Ray--Davis
Sky Air WiFi
On starting the TV it always says no internet connection, I have to mess around to get it working then it happens again the next time. Any ideas?
Re: Sky Air WiFi
Can you change to the  following recommended options set in the Sky Glass Settings>
Set Network standby mode to ON.
Turn wifi OFF under Network if connected via ethernet.
Once you have made the changes, straight away do a settings restart, to ensure the options have been set.
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Glass Tv or Sky Stream puck will perform a reboot. It will take a few minutes to complete
