5
This discussion topic has been answered Discussion topic: Settings
This message was authored by: Abdn607
Settings
Does anyone have good picture settings for Glass gen 2.
Ive copied the ones from previous posts and they do improve things but sometimes the blacks are quite pixelated.
Thank you
This message was authored by: BenJoBanjo Answer
Re: Settings
@Abdn607 wrote:
Was mainly itv but watched an old atar trek movie on sky movies and was quite bad.
Possibly due to it being an old film
ITV content is often poorly encoded and Sky Movies too can vary a lot in quality, especially if only viewing in HD.
A UHD HDR source with a higher bit-rate from the likes of Netflix, Prime Video, Disney+ or Apple TV+ will give you better image quality. Many of the more recent movies on Sky Cinema on demand can look decent in UHD with HLG HDR too.
Re: Settings
@Abdn607 These were posted in April by another customer. See what you think:
Measurements for HD/SD as follows:
Auto back-light off
Back-light 75-80. Adjust if you find the image to dark
Aspect ratio auto
HDR/DV pic mode dark
Contrast 46
Sharpness 0
Brightness 51
Colour 55
Hue 50
White balance
RG 12
GG 0
BG -6
RO 18
GO 0
BO -22
Local dimming on
Colour management
Red 51, 61, 0
Green 56, 30, 1
Blue 53, 52, 1
The rest don't change so controls don't work properly.
Re: Settings
Thank you
Pixellated blacks are often the result of poorly encoded, low bit-rate source material.
What are you watching when you see it at its worst?
Avatar for Abdn607
Level 4 icon
Re: Settings
Re: Settings
Avatar for Abdn607
Level 4 icon
Re: Settings
Hello,
Just wondering if anyone has any updated good picture settings?
Thank you
