Discussion topic: SKY tv CONNECTION issue
This message was authored by: NTS2008
Since we switched with SKY the SKY TV hasn't work. Seems Connection cables issue.
This message was authored by: Gincap
Re: SKY tv CONNECTION issue
Are you getting error messages on screen and if so what are they?
Sky Stream requires a very stable connection with a clear line of sight to your router for WiFi.  It is best to connect via Ethernet if possible and turn off WiFi in settings.
You can check your speed in the Netflix app under settings.
A rule of thumb is to reboot your TV to clear any software glitches i prefer a power off and reboot.
