Discussion topic: Remove / reinstall Sky Glass on wall
This message was authored by: domwakeford
Hi there, I have a 43" Sky Glass that was professionally mounted to a wall but since I'm about to move, I'll need to remove it. Are there any clear instructions for doing this?
Also, thinking ahead of getting it mounted again, I see that the Sky website has downloadable PDF templates for wall-mounting but (forgive my being dense here) they only seem to print as A4?
Thanks in advance.
XXXXX
Re: Remove / reinstall Sky Glass on wall
Hi @domwakeford
I guess the recommendation would be for you to get a professional to take it down and remount it. You would need to change the print settings to rescale the document, but not really that practical.
MikeAlanR
@domwakeford  Alternatively once the TV has been taken down use a suitable size sheet of paper and create a template from the existing holes in the wall.
If it's on the original Sky wall bracket then the set needs to be pulled slightly forwards from the lower edge so that it disengages and then lifted off the lugs on the top.
Avatar for domwakeford
Thanks so much, I hadn't realised I was that easy to lift off the wall! Taking the bracket off was less fun...
XXXXX
