2
This discussion topic has been answered Discussion topic: Remote
This message was authored by: Mim1
Remote
Where's my new remote
This message was authored by: Fothergill1 Answer
Re: Remote
Hi @Mim1 and welcome to the forum.  This is a customer help forum so you are not addressing Sky by posting on here.  A replacement remote usually takes 3-5 days to arrive so if it is longer than that I would give Sky a call.
Good luck.
Re: Remote
No idea.
Re: Remote
Good luck.
