Discussion topic: Remote
Message posted on 04 Jul 2024 02:51 PM
Remote
Hi my remote control is not working
Message posted on 04 Jul 2024 04:25 PM
Re: Remote
@Jo12900000 Welcome to the forum. Have a look at the links below remote troubleshooting guides:
You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth. Even though it sounds an unlikely solution it has got many faulty remotes working again (including my own).
If none of the above help then I would request a replacement at the following link: Streaming TV replacement remote
If you are lucky enough to have one available you can use a Sky Q remote while you wait for a replacement to arrive.
