3
This discussion topic has been answered Discussion topic: Remote
This message was authored by: Leesky2
Remote
Hi, my batteries have leaked again in my remote and it is now not working correctly.
This message was authored by: mikealanr Answer
Re: Remote
Hi @Leesky2
This is a customer helps customer forum. If the batteries were not the ones included in the remote, this would be accidental damage and you would need to buy a remote from Amazon. See: https://www.sky.com/help/articles/damaged-or-lost-sky-glass-remote
If the batteries were the ones that the remote shipped with, you should be covered by warranty. You can order a replacement here: https://www.sky.com/help/forms/streaming-tv-remote
Or you can call Sky customer service.
MikeAlanR
Avatar for Leesky2
Level 0 icon
Re: Remote
Hello, is there anyone available to help with ordering a new remote.
This message was authored by: Jporch316
Re: Remote
To order a new remote under warranty use the following link
Replace remote
Re: Remote
Hi @Leesky2
MikeAlanR
