Discussion topic: Remote volume
Message posted on 17 Nov 2024 09:33 AM
Remote volume
My remote has stopped working the volume. Everything else is fine. Changed batteries,try to re-pair it to the tv. Been fine for 2 years just happened out of nowhere 🤷🏼♂️
Message posted on 17 Nov 2024 07:55 PM
Re: Remote volume
Hi @Woodybrook. I note you have already tried re-pairing the remote again without success so have a read through the following troubleshooting guides to see if they help:
You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth. Even though it sounds an unlikely solution it has got many faulty remotes working again (including my own on a couple of occasions).
If you are still having problems I would contact Sky and request a replacement. However, I see you have had glass for 2 years so if you are out of warranty they may not replace the remote FOC. You can also get remotes on Amazon.
If you are lucky enough to have one available you can use a Sky Q remote while you wait for a replacement to arrive
Message posted on 17 Nov 2024 09:45 PM
Re: Remote volume
Cheers for that,I’ll give it a go
