Discussion topic: Remote voice mic not working
Message posted on 31 Aug 2025 10:00 AM
Hi, I've followed all the steps to see if that will make the mic work but nothing. Any other ideas?
Message posted on 31 Aug 2025 10:22 AM
Re: Remote voice mic not working
Hi @Pauladeverell04 and welcome to the forum. In the past when I find the voice control becomes unresponsive I just reboot the puck and it fixes the glitch. Go to Settings > System Management > Resets & Updates > Restart device. It takes about 3 minutes to completely reboot. You will have a blank screen for a while until the Sky logo appears.
Message posted on 31 Aug 2025 03:10 PM
Hi, is that on sky glass? Sorry, mine is just a regular sky q box.
Message posted on 31 Aug 2025 03:21 PM
Hi @Pauladeverell04 no problem but you posted your query on the Sky Glass forum which is an easy mistake to make.
It's 3 years since I moved from Sky Q so can't remember all the remedies but it wouldn't do any harm to reboot your Q box by unplugging it for a couple of minutes and then plugging it in again to see if this resolves your problem (it works on Sky Glass and Stream).
Good luck 😀
