Discussion topic: Remote not working
This message was authored by: Blackbeauty1
Remote not working
My remote won't connect to sky glass. I have tried 7&9 1&3 but nothing
Re: Remote not working
Hi @Blackbeauty1  and welcome to the forum.  Is it a new remote?  If so remove the back and check that when you removed the tag it did not break off leaving a bit between the battery terminals.  This is a fairly common issue.
The back can be very stiff the first few times you remove it so some people use rubber gloves to give them more grip.
