1
This discussion topic has been answered Discussion topic: Remote not working
This message was authored by: MattG69
Remote not working
Remote control not working
This message was authored by: Fothergill1 Answer
Re: Remote not working
@MattG69You could try to pair the remote again as follows:
  1. Press 7 and 9 together on your Sky remote for three seconds (This resets/clears the remote)
  2. Press 4 and 6 together for three seconds
  3. Press 1 and 3 together for three seconds (bluetooth mode).  A connected message should appear on your screen, press continue and it's all done.
If that doesn't help have a run through the folowing troubleshooting guides:
Troubleshooting guide
Remote help
You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth.  Even though it sounds an unlikely solution it has got many faulty remotes working again (including mine on two occasions).
If none of the above help then I would request a replacement at the following link: Streaming TV replacement remote
If you have one available you can use a Sky Q remote while you wait for a replacement.
Remote help
