Discussion topic: Remote not working
Message posted on 24 Jan 2024 04:21 PM
Remote not working
The remote is using wrong buttons for actions and won't work at all
on some
Message posted on 24 Jan 2024 04:41 PM
Re: Remote not working
@Lou-985 Welcome to the forum.
To help you try to get your remote working the links below are to remote troubleshooting guides:
You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth. Even though it sounds an unlikely solution it has got many faulty remotes working again (including mine on two occasions).
If none of the above help then I would request a replacement at the following link: Streaming TV replacement remote
If you have one available you can use a Sky Q remote while you wait for a replacement.
