Discussion topic: Remote controls
Message posted on 03 Aug 2024 11:01 AM
Remote controls
I have now been through about 7 remote controls on my 4 Sky Glass/Picks and now all are not working again.
I've tried the twisting technique which has been recognised and new batteries but now only have one working controller in whole house. I've been refused new remotes recently as well.
At present I can't change channels on my TV and during Olympics this isn't great. Anything else I can try. This is becoming a huge frustration. Sky Glass is great when it works but so often have to reset my TV as it has lines down it and was told it was a software problem. If this is still happening 2 years later and is a software problem why hasn't it been fixed?
Same with remote controls, why are they so poor in quality compared to every other remote.
I'm just so frustrated at the moment with this product
Message posted on 03 Aug 2024 11:10 AM
Re: Remote controls
Not sure if you have tried the below
The remote can be reset and paired again following these steps;
- Press and hold 7 and 9 together on your Sky remote for three seconds.
- Press and hold 4 and 6 together for three seconds.
- Press and hold 1 and 3 together for three seconds and follow the on-screen instructions.
Replace remote
https://www.sky.com/help/forms/streaming-tv-remote
Message posted on 03 Aug 2024 11:12 AM
Re: Remote controls
Unfortunately tried that on a couple of controllers I have knocking about but still not pairing.
As I say filled in form for new remote and got refused. At present got a TV and a puck which are useless due to the remotes at the mo
Message posted on 03 Aug 2024 11:16 AM
Re: Remote controls
Strange how these issues materialise
i have two glass tvs and 3 pucks and I'm still using the original remotes two and a half years in!
if you want i can escalate your post to the online sky community support team but it's likely they won't contact you until Monday
Message posted on 03 Aug 2024 11:17 AM
Re: Remote controls
As an interim measure if you have an old sky q remote these can be used to control sky glass
Message posted on 03 Aug 2024 11:18 AM
Re: Remote controls
Also Amazon stock replacement remotes for glass although a bit pricey ....
Message posted on 03 Aug 2024 11:19 AM
Re: Remote controls
I've been trying to find an old one!
Re: Remote controls
Please do
Message posted on 03 Aug 2024 11:21 AM
Re: Remote controls
I have escalated your post keep looking for an invitation to chat on this forum from one of the support team
Message posted on 03 Aug 2024 11:40 AM
Re: Remote controls
Thanks for escalating. We've sent an invite to @MrJonPace.
Tom
Message posted on 03 Aug 2024 01:05 PM
Re: Remote controls
I have had my 55inch tv and from the start and a puck and I am still using the same controllers, never had any problems
