3
This discussion topic has been answered Discussion topic: Remote control problem
This message was authored by: Dizzydee96
Can't connect to sky at all
This message was authored by: Jporch316 Answer
Re: Remote control problem
Hi @Dizzydee96
try the following
The remote can be reset and paired again following these steps;
  1.   Press and hold 7 and 9 together on your Sky remote for three seconds.
  2.   Press and hold 4 and 6 together for three seconds.
  3.   Press and hold 1 and 3 together for three seconds and follow the on-screen instructions.
Replace remote under warranty link
https://www.sky.com/help/forms/streaming-tv-remote
@Dizzydee96 Try the troubleshooting steps here:
Sky Glass or Sky Stream remote isn't working | Sky Help | Sky.com | Sky Help | Sky.com https://share.google/fT9vjBvk0emRUk93N
Hi @Dizzydee96
try the following
Avatar for Dizzydee96
Thanks. Tried resetting and re pairing to no avail
 Sky are sending a replacement remote control!
