Discussion topic: Re: Technical fault
This message was authored by: Suzbean
Re: Technical fault
I have a blue stripe across the screen
I WANT TO SPEAK TO SOMEONE
Re: Technical fault
@Suzbean go ahead and call. Or try turning your Glass off at the plug for an hour.
Re: Technical fault
Hi @Suzbean Sky will not call you following a post on this user forum and even if they read your post they wouldn't know who you are.
I had something similar on a Glass TV a couple of years  ago. A normal reboot didn't help so I left the TV unplugged from the wall socket overnight and the line disappeared and luckily in my case it never came back.
Give it a try but if it doesn't resolve the issue or if it keeps coming back you should call Sky for additional troubleshooting and if applicable a replacement TV (assuming it is still within its 24 month warranty).
