Discussion topic: Programme load and technical difficulties
Message posted on 24 Jul 2025 09:09 PM
While in live program picture stops with black line at the top and note wait until program loading but in a minute program stops with notification this program has a technical problem try again later.
Had a constant update the software and advised that if the fault keeps coming it may be a fault with the device and I may need it replaced. My Sky Glass is still under warranty but the second advisor didn't want to advise how to request a replacement.
Message posted on 24 Jul 2025 09:39 PM
Re: Programme load and technical difficulties
I'm having the same problem and cant actually speak to anyone from sky to help!
Message posted on 25 Jul 2025 11:40 AM
+1 same problem.. been happening all week
Message posted on 25 Jul 2025 11:48 AM - last edited: 25 Jul 2025 11:48 AM
@Tibette and @DP5 when this happens to me I find resetting the puck gets everything working correctly again (until the next time). This is best done in the Settings > System Management > resets & updates > Restart device menu (it takes a couple of minutes so don't worry when you get a blank screen for a bit)
Message posted on 25 Jul 2025 11:53 AM
Thanks, yes a reboot works, but then the next day the same issue occurs. Its not really a long term solution. Seems odd its just started and affecting a few people at once. Perhaps sky have performed a change?
Message posted on 25 Jul 2025 11:56 AM
@DP5 I know Sky are aware and are looking into a solution which will no doubt for part of an update in the future. Not ideal I know but in the interim the reboot is the only fix I have found. I have learnt from experience that messing about with trying other things doesn't work so as soon as I see the message I reboot.
