Discussion topic: Problems with Sky Glass Gen 2 Audio
Message posted on 30 Sep 2026 02:55 PM
I just got my new Glass Gen 2 TV and I'm having issues with the audio.
Voices sound.. muffled and crackley? Almost sounds like if you don't plug headphones in properly.. reminds me of the early 2000's cheap spongy headphones that came with a Walkman.
How do I fix this?!
Unsure if this is a hardware or software problem. I'm really unhappy, as I bought this to replace my old TV with (cheap) JBL soundbar, but the sound is unbearable.
Particularly awful sounding when watching YouTube videos.
If this is the 'standard' I'll sadly have to return the TV.
Message posted on 30 Sep 2026 03:11 PM
Re: Problems with Sky Glass Gen 2 Audio
Hi @jld93
Sound is one of the better functions of Glass. Try pressing the 3 dots on your remote and turning on Enhanced Audio and see if that helps. Failing that, it could be a faulty unit and you will need to get sky to replace under warranty.
MikeAlanR
