Discussion topic: Problem with sky glass
This message was authored by: Weymouth2025
Why does my tv keep saying please wait while we load your programmes
Re: Problem with sky glass
It's a known issue which allegedly has been resolved. Try power cycling your TV and see if it helps.
This message was authored by: peter-marlow+1966
How is  your  tv  connected  to the  Internet  wifi or ethernet cable, ethernet cable  is better and more stable  then wifi, and also what is your broadband  speed to the tv ? You fine this out by opening Netflix going to help opening that and running check my network, that will  show you  what speed your tv is getting
P c marlow
@Weymouth2025
A similar problem affected some customers.
It has been resolved with the latest UI release.
See this answered post on the 'now closed' thread.
https://helpforum.sky.com/t5/Sky-Glass-Live/Discussion-topic-There-is-a-technical-fault-Please-try-a...
If you still have a problem.
First if you have not done so already, try a restart of your Sky Stream box;
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete.
Could you also let us know how you connect your Puck, ethernet or wifi?
Plus, also provide us with a speed test as follows;
Launch Netflix on your pucks (you do not need to be logged into it, if you do not use netflix) and scroll down the left menu to Get help.
Choose Check Network.
Would suggest running the test a few times between tests, over a half hour period
What is your speed?
Can you let us know the UI version for your puck as listed in your puck settings, under Systems Management?
