7
This discussion topic has been answered Discussion topic: Problem with Playlist on Sky Glass
This message was authored by: Barry131
Sky Glass, using Playlist to watch back sport on Sky, comes up with message 'Please wait for your programme to load' and it never does, or 'There is a technical fault with this programme, try again later'.  I have rebooted, to no affect. Any suggestions?
Avatar for Barry131
This message was authored by: Barry131 Answer
Re: Problem with Playlist on Sky Glass
The problem seems to have righted itself.  Problem was with stuff on Playlist from Sky Sports in early hours of Tuesday morning (tennis & NFL). Nothing adverse since, if happens again will get back in touch.
This message was authored by: Jporch316
Hi - have you pulled the plus from the socket for a few minutes ? If this doesn't work please report back and I can escalate your post to the online sky community support team ....
@Barry131
It will still act  as a normal tv in so much as you can use apps and the hdmi sockets (same as a standard tv)
you won't get a tv EPG but adding a freeview player to one of the hdmi sockets would resolve this
not sure what more you would expect ?
Avatar for Barry131
Have unplugged for several minutes, still have the fault.
And please ignore one of my posts above it was meant for another thread ..... I'm not quite sure how it got posted here 🤷🏻‍♂️
@GD1   Are you able to delete my post above ..... I seem to have lost the ability to edit .....
This message was authored by: Lisa-P1987
Thanks for escalating this. We’ve sent an invite to chat.
Lisa - Sky Tech Team Expert
Avatar for Barry131
This message was authored by: John2212
I had the same problem, I have a Deco mesh system with the County Broadband router in bridge mode, I was on the phone to Sky support for over an hour, with no joy, he suggested unplugging the main router for about 20 minutes, I did this then turned it all back on only to find I couldn't link the Deco system,  I turned them all off for about a minute, turned them back on , hey presto I have WiFi again,  I turned on the tv later on, and it all seems to be working fine now.
