Discussion topic: Playlist won’t load
Message posted on 18 May 2025 11:31 AM
Playlist won’t load
Playlist isn't loading. Screen goes to blue and says let's try that again and press the home button. I've refreshed the apps, unplugged tv. Nothing is working. I can see most recent, movies, sport but the tv shows section is gone. Anyone help?
Message posted on 18 May 2025 11:36 AM
Re: Playlist won’t load
Would suggest trying a restart of your Sky Glass TV via the settings option;
On your Sky Glass TV, go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Glass TV will perform a reboot. It will take a few minutes to complete
Message posted on 18 May 2025 11:57 AM
@JulieT11 wrote:Playlist isn't loading. Screen goes to blue and says let's try that again and press the home button. I've refreshed the apps, unplugged tv. Nothing is working. I can see most recent, movies, sport but the tv shows section is gone. Anyone help?
I've seen this glitch once or twice and it has disappeared again after a few hours
in the meantime you can navigate to "manage" all in the playlist section to get to your shows
Message posted on 18 May 2025 05:42 PM
I've done this several times but still the same. It's been over 24 hours
Message posted on 18 May 2025 06:01 PM
have you pulled the plug on the tv for 5-10 minutes and rebooted your router ?
Message posted on 18 May 2025 07:03 PM
Not rebooted the router. I'll try that thanks
