Discussion topic: Playlist problem
This message was authored by: Robbo7131
Message posted on 23 Sep 2024 04:24 PM
Playlist problem
Is there anybody have a problem watching their playlist? Able to select program but unable to watch?
Find out more
Message posted on 23 Sep 2024 06:54 PM
Re: Playlist problem
@Robbo7131 My playlists are working correctly. Have you tried to restart/reboot your Glass TV? In not go to Settings > System Management > Resets & Updates > Restart device (do not do a factory reset). It takes about 3 minutes to completely reboot. You will have a blank screen for a couple of minutes before the Sky logo appears so don’t panic when you first start the process.
