3
This discussion topic has been answered Discussion topic: Playlist issue
This message was authored by: Decaff88
Playlist issue
Lately I seem to have a problem deleting anything from my playlist. I do the usual select the show and untick or choose remove but the shows are still there. Always worked fine until recently ?
I have done a reboot but it didn't help either ?
This message was authored by: Fothergill1 Answer
Re: Playlist issue
@Decaff88  If you go to the very bottom of your playlist there should be an option to "Manage All".  Select this and use the options there to delete the offending programme.  I have found this works for me when a specific programme won't delete in the normal way.
Re: Playlist issue
Avatar for Decaff88
Re: Playlist issue
Thanks, yes that's worked. Cheers 😀
This message was authored by: Dawnf1
Re: Playlist issue
I came to see if anyone was having the same problem as me, and this has solved it. Thanks!
