Discussion topic: Playlist TV shows doesn’t work
Message posted on 23 Jul 2025 06:53 AM
In my playlist, all the sport and movies that I've saved are there but my TV shows are not !!!! Any help would be greatly appreciated
Message posted on 23 Jul 2025 07:16 AM - last edited: 23 Jul 2025 07:16 AM
Re: Playlist TV shows doesn’t work
How many shows do you have in your playlist ? I seem to remember another user having this issue but they had over 450 shows saved....... once they cleared their playlist a little (through the playlist manage all menu) the playlist returned
Message posted on 23 Jul 2025 03:34 PM
I was told last week by Sky that few people had this issue since 30th June & they are working on it & no work around so even if you remove tv shows or add new Playlist it will still not show until they resolve it.
Message posted on 23 Jul 2025 07:42 PM
As a temporary measure go to playlist then "manage all"
You should see all the shows you have playlisted from there
Message posted on 23 Jul 2025 08:52 PM
Assuming you have tried a power restart of your Sky Glass or a Sky Glass settings restart?
You have not mentioned doing so.
If not, give it a try;
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Glass TV will perform a reboot. It will take a few minutes to complete
