8
This discussion topic has been answered Discussion topic: Not my sky package
This message was authored by: HWill
Not my sky package
My daughter has given me a new sky glass tv  but I don't have sky myself. Can I remove the sky connection? I only wanted a tv to use my firestick on and I don't want to use sky or get my daughter into trouble
This message was authored by: Anonymous Answer
Re: Not my sky package
@HWill You can't remove it (by that I mean Sky). Really your daughter should have carried out a factory reset before giving it to you.
You could do this by going into Settings, System Management, then following the on screen instructions when it reboots. It will take a few minutes to do this.
Once its rebooted you shouldn't be able to view any Sky channels but can view the apps like Netflix etc.
@HWill If your don't have a subscription then you don't have to do anything. You won't be able to view any of the Sky channels.
Avatar for HWill
But it's coming up with my daughters viewing history.. I just want to remove it from my tv ?
Avatar for HWill
It's asking me to reset but telling me it Wilson all account info and customised settings... will this just be on this tv? Or on my daughters sky account?
Avatar for HWill
It does say THIS DEVICE but I'm scared it will remove hers too and ill be i. Trouble
@HWill It just removes her details from the TV and removes the Glass from her Sky account. It doesn't affect her Sky viewing.
Avatar for HWill
Thanks so much for your help...  I'm an old lady lol so a bit unsure .
@HWill You're welcome. Hopefully, you've managed to get it restarted okay.
