Discussion topic: No signal technical issues
This message was authored by: EileenWilliams
Sky
Sorry, because of a technical issue, you're currently experiencing a limited service. Please be assured that we're working hard to fix
Re: No signal technical issues
@EileenWilliams
Is this on Sky Q, Glass or Stream ?
Avatar for EileenWilliams
Sky glass
Reboot the TV, unplug leave a few minutes to clear software glitches and power on this should clear it. Check your WiFi signal in settings if weak attach an Ethernet cable from your router.
@EileenWilliams
Would suggest first trying a restart of your Sky Glass TV
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Glass TV will perform a reboot. It will take a few minutes to complete.
Can you do a network speed test on your Sky Glass TV.
Launch Netflix on your the Glass TV (you do not need to be logged into it, if you do not use netflix) and scroll down the left menu to Get help.
Choose Check Network.
Would suggest running the test a few times, say over a half hour period.
What is your speed?
Are you using wifi or an ethernet cable connection?
It's also the signal upstairs won't connect
@EileenWilliams Is that also still only on TV or general broadband for any device?
