8
This discussion topic has been answered Discussion topic: No replacement sky glass remote
This message was authored by: LoganTV
Hi, I've had Sky Glass for a little over 2 months now and my remote for my first puck has just stopped working? What I mean by 'stopped working' is the following: most buttons do absolutely nothing on the home page but here's the weird bit. LEFT, 3 and POWER work...but they ALL turn the puck off. That's it! I've tried resetting the remote via various methods, holding down 1+3, 4+6, 7+9 etc. I've replaced the batteries, reset the puck itself and nothing has changed. I grabbed my remote from the Sky Glass itself and this worked perfectly fine once I got this connected. Is there any way to get a replacement remote? I did look on Sky but they say I have to buy a new one on Amazon!! I find it disgusting that I've not even had the thing for 3 months 😞
This message was authored by: Fothergill1 Answer
Re: No replacement sky glass remote
Hi @LoganTV welcome to the forum.  You appear to have already tried the obvious things.  You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth.  Even though it sounds an unlikely solution it has got many faulty remotes working again (including mine on two occasions).
If none of the above help then I would request a replacement at the following link: Streaming TV replacement remote
If you have one available you can use a Sky Q remote while you wait for a replacement.
@LoganTV   You are able to request a replacement Glass/Stream remote online and is simple to request using the following link https://www.sky.com/help/forms/streaming-tv-remote
If you are signed into your My Sky app first it will auto fill the form for you.
Avatar for LoganTV
Thanks for the reply, I'll let you all know how this goes.
This message was authored by: spower12a
This message was authored by: Padam_Padam
Use the link in the post marked 'Answer' to order a replacement remote.
@spower12a The Glass & Stream remotes are always causing issues.  You can request a replacement at the following link : https://www.sky.com/help/forms/streaming-tv-remote
As you have found out the Sky Q remotes are much better and I use one as a secondary remote
9apps apk
@spower12a  Just use the link in my previous post just above yours. The remotes reportedly arrive withing 3 to 5 days 😀
