Discussion topic: Help
This message was authored by: Nik541
Message posted on 03 Feb 2026 02:37 PM
Help
I can't seem to get sky glass for some reason
Message posted on 03 Feb 2026 04:04 PM
Re: Help
@Nik541 wrote:I can't seem to get sky glass for some reason
If you're having trouble placing an order for a Sky Glass TV on the website then try phoning Sky instead. It's possible that your credit rating is hampering the online ordering process. You might have better luck if you speak to them directly.
