Discussion topic: Hearing aid connection
Message posted on 16 Sep 2024 09:01 AM
Re: Hearing aid connection
@Alibobs wrote:The hearing aids don't connect at all to Sky Glass unfortunately
@Alibobs That certainly used to be the case but following a software update some time ago compatible hearing aids will work with Sky Glass. They need to be A2DP compliant.
Message posted on 16 Sep 2024 09:47 AM
Sky glass is one on it's own!
Message posted on 16 Sep 2024 10:56 AM
Thank you. Will try again!
Message posted on 16 Sep 2024 11:41 AM - last edited: 16 Sep 2024 11:42 AM
@Alibobs You can only connect hearing aids to Glass via bluetooth and as mentioned they must be A2DP compliant.
Good luck
Message posted on 16 Sep 2024 08:55 PM
Not all hearing aids will connect to Glass so might be worth buying a hraing loop that connects to Bluetooth and will then link directly to hearing aids using the T Switch. We have a room loop system supplied via British Institute for the Deaf. It is not Bluetooth so purchased a Bluetooth receiver/transmitter (cost from £7 via Amazon) which received the Bluetooth sound from the Sky Glass set and will feed this into the loop control box, so again, you can listen via the T switch on the hearing aids.w
Message posted on 19 Apr 2025 01:09 PM
My hearing aids have Bluetooth. I've been ok with them but since I changed to Sky I can't get to direct to them
Message posted on 08 May 2025 02:16 PM
My wife has Phonak Sphere aids, and the Sky Glass is not seeing them advertised as a Bluetooth connection.
Is there something more complex needed than just setting them into Bluetooth discovery mode?
Message posted on 08 May 2025 02:56 PM
@Ineluki wrote:My wife has Phonak Sphere aids, and the Sky Glass is not seeing them advertised as a Bluetooth connection.
Are the Phonak Sphere aids A2DP compliant? Sky Glass needs them to be, otherwise they won't work.
Message posted on 13 May 2025 07:36 PM
We've been unable to connect the phonaks to the Glass. I can get them to pair, but it always fails to connect.
Message posted on 13 Jun 2025 10:18 PM
I'm getting Sky Glass Gen 2 on the 25th June. I have 6 pairs of working Phonak Hearing Aids, and have them all paired to a Phonak TV Connector. However, with there being no Optical output, I shall firstly try Bluetooth. If this is unsuccessful, I shall buy an eARC HDMI sound splitter, so I can connect the TV Connector to via HDMI 2
I'll update.
Message posted on 25 Jun 2025 02:49 PM
Update on Phonak Hearing aids (from 2019) and my new Sky Glass Gen 2 55":
Firstly all my hearing aids pair easily. Here's the process:
1) Reboot the hearing aids to put them in pairing mode
2) Settings / Connected Devices / Bluetooth Devices / Add new device
3) Search .... 1 Hearing aid should appear
4) Pair it and Connect
5) Press the " ... " button
6) Go to Audio Output, and choose the option you want out of Speaker, Bluetooth or both.
The pairings stay there, but you have to connect each time. It doesn't take long (I've just noticed the Auto-connect option!
To be honest, I doubt I'll use this much though, as the main speakers are great.
I've not managed to get the TV Connector to work, but that could be the cheap eARC extractor.
Phonak use Classic Bluetooth for these connections.
Hope this helps
SKY Glass Gen 2 55"
900mb Ethernet
Phonak Hearing Aids
Phonak TV Connector
Message posted on 21 Sep 2025 11:48 PM
Update on this.
I've secured an ARC extractor that actually works, and have connected it to my Phonak TV Connector (V1). It now works and, initially, seemed a vast improvement on the Bluetooth connection, certainly regarding latency.
However!!!
- Sadly, once this connection is established, the TV speakers are switched off. Unlike a Bluetooth connection, there doesn't appear to have an option of both speakers and hearing aid streaming.
Oh well.
For the most time, I view TV alone, so I have many options, but when in company, it's clear the excellent Phonak TV Connector really isn't an option with Sky Glass.
Shame
SKY Glass Gen 2 55"
900mb Ethernet
Phonak Hearing Aids
They work with Sky Glass Gen2 via Bluetooth
Phonak TV Connector
They don't work with Sky Glass Gen2
Message posted on 15 Jan 2026 03:14 PM
Thank you for all the work you have done in researching this and for your updates. We have just bought a Sky Glass TV recently, and this whole area of a proper lack of access for the hearing impaired, is for me a huge mistake by Sky.
I have bought an HDMI ARc converter and spent too much time trying to get it set up with zero success. Yes as above I can get the sound into my hearing aids but the TV speakers are silent.
I'll go try the Bluetooth connect again and see if I have any more success there.
I truly hope someone from Sky is taking note here.
Message posted on 06 Mar 2026 07:46 AM
Update on this post. After several attempts via Bluetooth and HDMI arc connections I had to admit defeat and send my Sky Glass back. Needless to say we were very disappointed as the glass is a great product but without the proper output for the hearing aid a tv connector it was unusable for me.
hopefully SKY will take note of this issue and rectify / include the correct audio output port on a future version.
Message posted on 06 Mar 2026 07:57 AM
Sadly, it seems to be a trend with TV manufacturers, to remove the optical output. 😞
